CVARCTESSELLATIONTEMPLATEELEMENT system variable
Template Element arc approximation mid-ordinate distance
Controls the corridor mid-ordinate distance (1), the maximum distance between the arc and the chord (straight) segment, used for arc approximation.
BricsCAD only
| Type: |
Real |
| Saved in: |
Drawing |
| Default value: |
0.01 |
