CVASSOCIATIVITY system variable
Associativity
Controls if Civil entities are associative.
BricsCAD only
Type:
Short
Saved in:
Drawing
Default value:
15
Possible values:
1: TIN Surfaces are associative
2: Gradings are associative
4: TIN Volume Surfaces are associative
8: Corridors are associative
Related commands
  • CORRIDOR command
  • GRADING command
  • TIN command
  • -TIN command
  • TINVOLUME command
