DEFAULTLIGHTING system variable
Default lighting
Controls if default lighting overrides other lights in the drawing. Default lighting is a distant light that follows the view direction, can be set per viewport.
| Type: |
Boolean |
| Saved in: |
Drawing |
| Default value: |
0 |
| Possible values: |
Off (0): Default lighting is used only when no other lights are switched on On (1): Default lighting overrides other lights. |
