DEFAULTSTYLEPIPEELBOW45 system variable
Default style for pipe elbow (45 deg)
Controls the default style in use while BIM FlowBends with 45 degrees angle converts to an Std part.
BricsCAD only
| Type: |
String |
| Saved in: |
Registry |
| Default value: | ASME B16.9 Elbow LR 45 Deg |
