DEFLPLSTYLE system variable
Default layer plot style
Controls the default plot style for layer 0. "BYCOLOR" in color-dependent mode drawings, read-only. "NORMAL" in named-plot-style mode drawings, can be changed. See also the PSTYLEMODE system variable.
Note: To convert the current drawing to use named or color-dependent plot styles, use CONVERTPSTYLES
| Type: |
String |
| Saved in: |
Registry |
