DEFPLSTYLE system variable
Default entity plot style
Controls the default plot style for new entities. "BYCOLOR" in color-dependent mode drawings, read-only. "NORMAL" in named-plot-style mode drawings, can be changed. See also the PSTYLEMODE system variable. Use the CONVERTPSTYLES command to convert the current drawing to use named or color-dependent plot styles.
| Type: | String |
| Saved in: | Registry |
