DELETEINTERFERENCE system variable
Delete interference
Specifies whether interferences between source and other 3d solids are retained or resolved (i.e. source solids will be subtracted from any interfering solids).
BricsCAD only
| Type: | Boolean |
| Saved in: | Registry |
| Default value: | On |
| Possible values: |
Off (0): Don’t solve interferences after commands On (1): Solve interferences after commands |
