DELETEINTERFERENCE system variable
Delete interference
Controls the behavior of the INTERFERE command.
If on, the first set of solids are subtracted from the second set.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
| Possible values: |
Off (0): Don’t solve interferences after commands On (1): Solve interferences after commands |
