DELETETOOL system variable
Delete tool
Controls the behavior of the SUBTRACT command. If on, entities used to subtract are deleted.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Workspace |
| Default value: |
Off Note: The default value is On for BIM workspace.
| Possible values: |
Off (0): Don’t delete tool entities in command SUBTRACT On (1): Delete tool entities in command SUBTRACT |
