DELOBJ system variable
Delete source entity
Controls if source entities, used to create 3D entities (with commands such as EXTRUDE, REVOLVE and LOFT) are retained or deleted.
| Type: | Short |
| Saved in: | Registry |
| Default value: | 1 |
| Possible options: |
0: Retain defining entities 1: Delete profile entities 2: Delete all defining entities -1: Prompt to delete profile entities -2: Prompt to delete all defining entities (including paths and reference curves) |
Note: An entity is deleted only if it is used in its entirety to create the 3D entity. Scenarios in which entities are retained are shown in the examples below:
- If only a part of a polyline is used in the operation, the entire polyline is retained because the unused part is not a defining entity.
- If an entity is included in the selection set but not used to define a region, it is retained (for example, an open, isolated polyline).
- If overlapping entities are used to create a region, some entities are retained, even if they are entirely on the boundary.
