DEMANDLOAD system variable
Demand load
Controls how the program handles custom entities created by third-party applications.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 3 |
| Default value: |
3 |
| Possible values: |
1: Demand-load source application when opening a drawing that contains custom entities 2: Demand-load source application when invoking one of the application's commands |
Note: If you set this system variable to 0, third-party applications and some internal commands may not function.
