DETAILSPATH system variable
Details directory path
The file path(s) for user created detail files.
Separate file paths with semicolons (;).
BricsCAD only
Type:
String
Saved in:
Registry
Related commands
  • BIMCREATEDETAIL command
  • BIMPARAMETRIZEDETAIL command
