DGNEXPXREFMODE system variable
Export Conversion of Xrefs
Specifies conversion of references to xrefs. The dependent files themselves are not converted when exporting the parent. They must be converted separately.
BricsCAD only
| Type: |
Short |
| Saved in: |
Preference |
| Default value: |
0 |
| Possible values: |
0: Convert reference to DGN 1: Keep reference to DWG 2: Bind reference file to the parent DGN 3: Detach xref |
