DGNIMPCONVERTDGNCOLORINDICESTOTRUECOLORS system variable
Convert DGN color indices to true colors
Specifies how Microstation colors are mapped to BricsCAD colors. Microstation assigns color numbers to colors that are different from BricsCAD. If on, then BricsCAD converts dgn color indexes to RGB true colors. Otherwise it tries to convert dgn color indices to dwg color indices. BricsCAD gets the color from the dgn color table and tries to find the same color in dwg color table. If it is not possible, then the color will be saved as an RGB true color to the dwg file.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: | Off |
| Possible values: |
Off (0): Convert DGN color indices to DWG color indices On (1): Convert DGN color indices to RGB true colors |
