DGNIMPCONVERTEMPTYDATAFIELDSTOSPACES system variable
Convert empty data fields to spaces
Specifies how empty field values are handled. If on, then empty field values from a dgn file are replaced by space symbols in the dwg file. Otherwise empty field values from a dgn file are replaced by underscore symbols ("_") in the dwg file.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: | On |
| Possible values: |
Off (0): Replace by underscore symbols ("_") On (1): Replace by space symbols |
