DGNIMPCONVERTEMPTYDATAFIELDSTOSPACES system variable
Convert empty data fields to spaces
Replaces empty field values from a DGN file with space symbols. If off, empty field values from a DGN file are replaced with underscore symbols ("_").
BricsCAD only
Type: |
Boolean |
Saved in: |
Preference |
Default value: |
On |
Possible values: |
Off (0): Replace by underscore symbols ("_") On (1): Replace by space symbols |
