DGNIMPEXPLODETEXTNODES system variable
Explode text nodes
Imports DGN text nodes as a set of simple entities (text, line, etc.). If off, DGN text nodes are converted to multiline text.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: | Off |
| Possible values: |
Off (0): Convert text nodes to multiline text On (1): Convert text nodes to simple entities, such as text and lines |
