DGNIMPIMPORTPAPERSPACEMODELS system variable
Import Paper Space models
Imports all DGN sheet models to paper space layouts. If off, sheet models are not imported.
Note: Microstation uses the phrase “sheet model” for paper space.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
On |
| Possible values: |
Off (0): Don’t import sheet models On (1): Import sheet models to paper space layouts |
