DGNIMPIMPORTVIEWINDEX system variable
Import view index
Controls the number of DGN views, level masks and view settings to use.
Values between -1 and 7 are accepted. -1 means that the view is not defined and view settings and level masks are not used.
Note: Microstation uses the word "level" for layers; a "mask" hides content in areas or levels/layers.
BricsCAD only
| Type: |
Short |
| Saved in: |
Preference |
| Range: |
-1 to 7 |
| Default value: |
-1 |
| Possible values: |
-1: View is not defined 1 to 7: Specifies level mask |
