DGNIMPIMPORTVIEWINDEX system variable
Import view index
Specifies the number of dgn views to use level masks and dgn view settings. If the view number is "-1", then the view is not defined, and view settings and level masks are not used. Microstation uses the word "level" for layers; a "mask" hides content in areas or levels/layers.
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Range: |
-1 to 7 |
| Default value: |
-1 |
| Possible values: |
-1: View is not defined 1 to 7: Specifies level mask |
