DGNIMPRECOMPUTEDIMENSIONSAFTERIMPORT system variable
Recompute dimensions after import
Converts DGN dimensions to DWG-based dimensions.
If off creates DGN-based dimensions.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
Off |
| Possible values: |
Off (0): create DGN-style dimension geometry blocks On (1): re-compute all dimensions to create DWG dimension geometry blocks |
