DGNIMPXREFIMPORTMODE system variable
External references import mode
Controls DGN attachment import.
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
0 to 3
Default value:
2
Possible options:
0: Omit - does not import DGN attachments
1: Retain - converts attached DGN files to DWG XRefs
2: Merge to cell - converts attached DGN files to DWG blocks
3: Create DGN Underlay - converts attached DGN files to Underlay entities
