DIMALTD system variable
Alt precision
Controls the number of decimal places for alternate dimension units.
Type:
Short
Saved in:
Drawing
Range:
0 to 8
Default value:
2
Note: The default value applies when the MEASUREMENT system variable is set to 0 and the INSUNITS system variable is set to inches. When the MEASUREMENT system variable is set to 1 and the INSUNITS system variable is set to millimeters, the default value is 3.
