DIMALTTD system variable
Alt tolerance precision
Controls the tolerance precision in the alternate dimension units.
| Type: | Short |
| Saved in: | Drawing |
| Range: | 0 to 8 |
| Default value: | 2 Note: The default value applies when the MEASUREMENT system variable is set to 0 and the INSUNITS system variable is set to inches. When the MEASUREMENT system variable is set to 1 and the INSUNITS system variable is set to millimeters, the default value is 3.
