DIMALTTD system variable
Alt tolerance precision
Controls the tolerance precision in the alternate dimension units.
Type:
Short
Saved in:
Drawing
Range:
0 to 8
Default value:
3 - If MEASUREMENT=1 and INSUNITS= inches
2 - If MEASUREMENT=0 and INSUNITS=millimeters
Related commands
  • DIM command
Related variables
  • INSUNITS system variable
  • MEASUREMENT system variable
