DIMAPOST system variable
Alt units prefix/suffix
Controls the prefix and/or suffix that appears in the alternate dimension text, does not apply to angular dimensions. See also the (DIMSTYLE command).
Set to '' to turn off, or use the suffix string 'prefix[]suffix'. Insert a single linefeed with '\X' (often when alternate units are active).
| Type: | String |
| Saved in: | Drawing |
