DIMASZ system variable
Arrow size
Controls the size of dimension and leader line arrowheads.
Type:
Real
Saved in:
Drawing
Default value:
0.18
Note: The default value applies when the MEASUREMENT system variable is set to 0 and the INSUNITS system variable is set to inches. When the MEASUREMENT system variable is set to 1 and the INSUNITS system variable is set to millimeters, the default value is 2.5.
