DIMATFIT system variable
Arrow and text fit
Controls how dimension text and arrows are arranged when there is insufficient space between the extension lines.
When the DIMTMOVE system variable is set to 1, a leader is added if the dimension text is placed outside.
Type:
Short
Saved in:
Drawing
Range:
0 to 3
Default value:
3
Possible options:
0: Place both text and arrows outside extension lines
1: Move arrows first, then text
2: Move text first, then arrows
3: Move either text or arrows, whichever fits best
