DIMAUNIT system variable
Dim angle units
Controls the angular dimension unit type.
| Type: | Short |
| Saved in: | Drawing |
| Range: | 0 to 3 |
| Default value: | 0 |
| Possible options: |
0: Decimal degrees 1: Degrees/minutes/seconds 2: Gradians 3: Radians |
