DIMBLK system variable
Arrow
The name of the block displayed at the ends of dimension and leader lines, when the DIMSAH system variable is set to Set by DIMBLK.
The block name can be either a standard name or refer to a user-defined arrowhead block.
| Type: |
String |
| Saved in: |
Drawing |
