DIMBLK1 system variable
Arrow 1
The name of the block displayed at the first end of a dimension line, when the DIMSAH system variable is set to Set by DIMBLK1 and DIMBLK2.
Type:
String
Saved in:
Drawing
Related commands
  • -DIMSTYLE command
  • DIMSTYLE command
Related variables
  • DIMSAH system variable
