DIMCEN system variable
Center mark
Controls if and how center marks and centerlines of circles and arcs are drawn with the DIMCENTER, DIMDIAMETER and DIMRADIUS commands.
  • A value of zero means no center mark.
  • Negative numbers mean a line.
  • Positive numbers mean a mark.
Type:
Real
Saved in:
Drawing
Default value:
0.09
Note: The default value applies when the MEASUREMENT system variable is set to 0 and the INSUNITS system variable is set to inches. When the MEASUREMENT system variable is set to 1 and the INSUNITS system variable is set to millimeters, the default value is 2.5.
Possible values:
0: None
<0: Line
>0: Mark
