DIMCONTINUEMODE system variable
Dim continue mode
Controls if dimension styles and layers are inherited from the starting dimension, for continued or baseline dimension.
| Type: |
Short |
| Saved in: |
Registry |
| Default value: |
1 |
| Possible values: |
0: Use the current dimension style and layer 1: Use the dimension style and layer of the starting dimension |
