DIMDLI system variable
Dim baseline spacing
Controls the spacing between baselines dimension lines.
Type:
Real
Saved in:
Drawing
Default value:
0.38 - If MEASUREMENT=0 and INSUNITS=inches
3.75 - If MEASUREMENT=1 and INSUNITS=millimeters
Related commands
  • DIMSTYLE command
  • -DIMSTYLE command
Related variables
  • INSUNITS system variable
  • MEASUREMENT system variable
