DIMEXE system variable
Ext line ext
Controls the extension of dimension extension lines beyond the dimension line.
Type:
Real
Saved in:
Drawing
Default value:
0.18
Note: The default value applies when the MEASUREMENT system variable is set to 0 and the INSUNITS system variable is set to inches. When the MEASUREMENT system variable is set to 1 and the INSUNITS system variable is set to millimeters, the default value is 1.25.
