DIMEXO system variable
Ext line offset
Controls the offset of dimension extension lines from their origin points.
Type:
Real
Saved in:
Drawing
Default value:
0.0625
Note: The default value applies when the MEASUREMENT system variable is set to 0 and the INSUNITS system variable is set to inches. When the MEASUREMENT system variable is set to 1 and the INSUNITS system variable is set to millimeters, the default value is 0.625.
