DIMFXLON system variable
Ext line fixed
Fixes the length of extension lines on dimensions.
| Type: | Boolean |
| Saved in: | Drawing |
| Default value: | Off |
| Possible values: |
Off (0): Don’t use fixed length extension lines On (1): Use fixed length extension lines |
