DIMGAP system variable
Text offset
Controls the offset distance around dimension text, and the distance between annotations and hook lines created with the LEADER command.
See the DIMTAD system variable. Negative numbers mean draws a box around the dimension or annotation text.
| Type: |
Real |
| Saved in: |
Drawing |
| Default value: |
0.09 - If MEASUREMENT=0 and INSUNITS=inches 0.625 - If MEASUREMENT=1 and INSUNITS=millimeters |
