DIMJUST system variable
Text Position Horizontal
Controls the horizontal position of dimension text.
Type:
Short
Saved in:
Drawing
Range:
0 to 4
Default value:
0
Possible options:
0: Text above the dimension line and center-justified between extension lines
1: Text next to the first extension line
2: Text next to the second extension line
3: Text above and aligned with the first extension line
4: Text above and aligned with the second extension line
