DIMLIM system variable
Tolerance method
Generates dimension limits as the default text for dimensions.
If On, switches DIMTOL Off.
| Type: |
Boolean |
| Saved in: |
Drawing |
| Default value: |
Off |
| Possible values: |
Off (0): Don’t generate dimension limits as default text On (1): Generate dimension limits as default text |
