DIMMARKTYPE system variable
Dimension override marking
Automatically displays overridden associative dimensions with a special marking (underline/overline) without database modification.
BricsCAD only
| Type: |
 Short  |
| Saved in: |
 Drawing  |
| Range: |
 0 to 2  |
| Default value: |
 0  |
| Possible values: |
 0: Not enabled 1: Display overridden dimensions with an underline 2: Display overridden dimensions with an overline  |
