DIMMARKTYPE system variable
Dimension override marking
Automatically displays overridden associative dimensions with a special marking, when they do not include the default dimension text.
BricsCAD only
| Type: |
Short |
| Saved in: |
Drawing |
| Range: |
0 to 2 |
| Default value: |
0 |
| Possible values: |
0: Not enabled 1: Display overridden dimensions with an underline 2: Display overridden dimensions with an overline |
