DIMPOST system variable
Dim prefix/suffix
Controls the prefix and/or suffix added to dimension text. See also the (DIMSTYLE command).
Set to '' to turn off, or use the suffix string 'prefix[]suffix'. Insert a single linefeed with '\X' when alternate units are active.
| Type: |
String |
| Saved in: |
Drawing |
