DIMSAH system variable
Arrowheads
Controls how dimension line arrowhead blocks are set.
Type:
Boolean
Saved in:
Drawing
Default value:
0
Possible values:
Off (0): Set by DIMBLK - uses the same block for the first and the second arrowhead
On (1): Set by DIMBLK1 and DIMBLK2 - uses different blocks for the first and the second arrowhead
Related variables
  • DIMBLK system variable
  • DIMBLK1 system variable
  • DIMBLK2 system variable
Octave
