DIMSCALE system variable
Dim scale overall
Applies a scale multiplier to dimension variables that specify the size of the components of dimension entities, such as text height, distance or offsets.
Note: It does not affect measured lengths, coordinates, or angles.
| Type: | Real |
| Saved in: | Drawing |
| Range: | 0 or greater |
| Default value: | 1.0 |
| Possible values: |
0: An appropriate default value is used based on the scaling between the current model space viewport and paper space. If you are not using the paper space feature and you are in paper space or model space, the scale factor is 1. > 0: A scaling factor is calculated so that text sizes, arrowhead sizes, and other scaled distances appear at the desired values when plotted. |
