DIMSOXD system variable
Dim line inside
Suppresses arrowheads outside extension lines if there is insufficient room inside the extension lines and if the DIMTIX system variable is on (1).
| Type: | Boolean |
| Saved in: | Drawing |
| Default value: | Off |
| Possible values: |
Off (0): Don’t suppress outside arrowheads On (1): Suppress outside arrowheads |
