DIMTAD system variable
Text Position Vert
Controls the vertical position of text in relation to dimension lines. The position above dimension line is set by the DIMGAP system variable.
The Above dimension line option does not apply if the DIMTIH system variable is set to Horizontal and the dimension line is not horizontal.
| Type: |
Short |
| Saved in: |
Drawing |
| Range: |
0 to 4 |
| Default value: |
0 |
| Possible options: |
0: Centered between extension lines 1: Above dimension line 2: Farthest from defining points 3: Japanese Industrial Standards 4: Below dimension line |
