DIMTM system variable
Tolerance limit lower
Controls the minimum (lower) tolerance limit for dimension text when the DIMTOL or DIMLIM system variable is on.
Type:
Real
Saved in:
Drawing
Default value:
0.0
Related variables
  • DIMLIM system variable
  • DIMTOL system variable
