DIMTOFL system variable
Dim line forced
Forces a dimension line to be drawn between dimension extension lines, even when text is placed outside.
| Type: | Boolean |
| Saved in: | Drawing |
| Default value: | Off |
| Possible values: |
Off (0): Don’t force dimension lines even when text is outside On (1): Force dimension lines even when text is outside |
