DIMTVP system variable
Text offset vertical
Controls the vertical position of dimension above or below the dimension line. Acts as a multiplier of the DIMTXT system variable, when the DIMTAD system variable is set to Centered between extension lines.
A value of 1.0 is equivalent to setting the DIMTAD system variable to on (1).
| Type: |
Real |
| Saved in: |
Drawing |
| Default value: |
0.0 |
